Wired Intelligent Edge
Catalyst 3560G series PoE-48 config *.txt import to Aruba 2530 48G PoE+ Switch
  • 1.  Catalyst 3560G series PoE-48 config *.txt import to Aruba 2530 48G PoE+ Switch
    Posted Jun 10, 2019 08:39 PM
    Is it possible to import a *.txt config file from Cisco Catalyst 3560G series PoE-48 and import it to Aruba 2530 48G PoE+ Switch?
  • 2.  RE: Catalyst 3560G series PoE-48 config *.txt import to Aruba 2530 48G PoE+ Switch
    MVP GURU
    Posted Jun 11, 2019 02:27 PM
    No...
    need to be convert (and there is no tools for this !)
  • 3.  RE: Catalyst 3560G series PoE-48 config *.txt import to Aruba 2530 48G PoE+ Switch
    MVP GURU
    Posted Jun 11, 2019 04:34 PM
    As pointed out by @alagoutte you can't simply export a Cisco IOS NOS based Switch's configuration and import (copy) it - as-is - into an ArubaOS-Switch NOS based Switch...Cisco and Aruba (HP/HPE/Aruba) don't use the same NOS Network Operating System (it's a matter of Cisco IOS versus ProVision/ArubaOS-Switch).
    You need to examine your actual configuration and try to replicate it by adapting (for what is possible) its commands to cope with ArubaOS-Switch equivalent ones.
    There is a nice guide that help doing so. Check it here or here (and also one a little bit older here).
    A brief (but interesting) presentation about how Cisco and HP/HPE/Aruba approach VLAN tagging and Port Aggregtion their own way is here.
