ceiling mounting kit for AP 274?
  • 1.  ceiling mounting kit for AP 274?
    Posted Apr 17, 2015 12:06 PM
    I want to ceiling mount AP 274(antenna used are ANT-3x3-2005 & ANT-3x3-5005), which mounting kit should i use?
    Thanks.
  • 2.  RE: ceiling mounting kit for AP 274?
    Posted Apr 17, 2015 08:09 PM
    The 274 should have a kit to ceiling mount it.  Do you mean you want to ceiling-mount the antennas?
  • 3.  RE: ceiling mounting kit for AP 274?
    Posted Apr 17, 2015 10:47 PM
    hi colin, thanks for your reply
    i want to mount ap 274 to ceiling, can you please help me with the correct part code number. can i use AP-270-MNT-H1 .
    Another query which I had was that in 274, will the antennas be mounted at the bottom of the AP?
  • 4.  RE: ceiling mounting kit for AP 274?
    Posted Apr 18, 2015 07:55 AM
    mohan007,
    I apologize, I thought you were talking about the 224 when I answered.  The ceiling mount kit is not included and like you mentioned it should be the AP-270-MNT-H1.  You are correct.
    The question is why would you not just ceiling mount the AP-275, instead of getting external antennas?  What kind of area are you trying to cover?
