Network Management
CentOS stuck in loop
  • 1.  CentOS stuck in loop
    Posted Mar 02, 2021 02:22 PM
    Just installed  ova for fresh install of 8.2.10  for CentOS upgrade following upgrade from 8.2.9 to 8.2.10 and performed backup. (VM btw)  At console I am prompted for logon. Then proceed thru steps 1 thru 4. Not prompted for step 5. Proceed thru step 6. Step 7 builds cert and system returns to console prompt and cycle begins again. Suggestions ?​
    Dave Wagner
  • 2.  RE: CentOS stuck in loop
    Posted Mar 02, 2021 02:35 PM
    This was seen sometimes while using the OVA file. If its for production i would recommend ISO instead of OVA as OVA is mainly for lab setup. In this case we can either use ISO and do the install, or involve a TAC, where they can get into rescue mode and update the config file to get the loop issue fixed.
    Vishnu Mannil
    Aruba ERT
    If my post addresses your query, give kudos :)
  • 3.  RE: CentOS stuck in loop
    Posted Mar 02, 2021 04:29 PM
    Many thanks and multiple KUDOS
    Dave Wagner
