Cloud Managed Networks
Central and AppRF
  • 1.  Central and AppRF
    Posted Sep 23, 2019 08:51 AM
    I have 4 IAP Clusters in Central.  I have AppRF set to "All" on all clusters.  However only one cluster is showing AppRF data.  The one working cluster doesnt seem to be showing all traffic, I think it is only from one SSID.  What settings could I be overlooking?  Since it is doing DPI, should I be loading a cert on clients?
  • 2.  RE: Central and AppRF
    Posted Sep 23, 2019 11:42 PM
    Which version are your IAP's running? There is currently an issue which will be fixed with a software upgrade:
    Slave IAPs running firmware versions 8.5.0.0, 8.5.0.1, and 8.5.0.2 fail to send client application usage data to Aruba Central. This issue will be resolved in 8.5.0.3.
