I want to use 80Mhz wide channels for our 6Ghz radios so I am only setting it up for the 6Ghz radio in the ARM profile and leaving the 5Ghz radio to 20Mhz.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/ee57089b28d04e089c13316a4df6a15a.png)
The issue is that the 5Ghz radio for some reason is also at 80Mhz even though it is not checked off.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/c0ed020a8fed422f953532c81e9f1701.png)
In AOS 10 this is not an issue but in AOS 8 Instant it seems to be?
Running 8.10.0.13. AP-635s
Aruba Partner Ambassador ACMP, ACDP, ACCP, ACEP
