Cloud Managed Networks
Central AP Radio Profiles and Aruba ARM
This thread has been viewed 34 times
  • 1.  Central AP Radio Profiles and Aruba ARM
    Posted Sep 06, 2023 01:19 PM
    Hello
    We have recently migrated to Aruba Central and AOS 10 for most of our network.
    We are using the default radio profile and the feeling we are getting is the platform have lowered the dBm output on devices and hence the cell size in the overall network.  We are now getting tickets from all over on poor Wi-Fi performance.  What I'm struggling in grasping and finding information on is how the Central Radio Profiles Allowed Transmit Power settings work together with Aruba ARM, what settings has priority and how does the setting affect, if any the ARM algorithm?
    Grateful if anyone can point me in the right direction.
  • 2.  RE: Central AP Radio Profiles and Aruba ARM
    Posted Sep 06, 2023 11:06 PM
    you can add various radio profiles from here, by clicking on the + sign.
    here i have added a new radio profile
    then you can assign these radio profile selectively to your APs
  • 3.  RE: Central AP Radio Profiles and Aruba ARM
    Posted Sep 07, 2023 03:27 AM
    Yes thanks, my question is more about how the radio profiles and the ARM algorithm works together. For example I have adjusted the default radio profile to minimum 18dBm for the 5GHz radio, still some of the AP have TX Power of only 13 dBm, why is that?
  • 4.  RE: Central AP Radio Profiles and Aruba ARM
    Posted Sep 07, 2023 03:38 AM
    AOS10 uses Airmatch for radio mgmt.
    you can get more info on it from here
  • 5.  RE: Central AP Radio Profiles and Aruba ARM
    Posted May 29, 2024 03:17 PM
    Did you ever figure out a solution to your problem?
