Aruba Central
Central IAP/WIN Client Gets De-Auth: Age-Out
  • 1.  Central IAP/WIN Client Gets De-Auth: Age-Out
    Posted Jul 17, 2022 05:29 PM
    Team... I can't seem to pinpoint the root cause. WIN10 client device/laptop unable to join no longer able to join WLAN -WPA2-PSK (LAB); I can't seem to pinpoint the root cause or settings to check on the WLAN or etc. Per attached - any feedback on where to check into. WLAN Profile was deleted from WIN Client
    Failure Stage: KEYEXCHANGE
    Failure reason: Client Time out.
    IAP FW Ver: 8.9.0.1_82154/AP55
    TIA
    nowires01
  • 2.  RE: Central IAP/WIN Client Gets De-Auth: Age-Out
    Posted Jul 17, 2022 07:38 PM
    Issue resolved. I had planned to clear the PMK Cache for this specific client, but when AP is connected to Central, you don't have the right privilege mode capability to conf t, and run cmds. without removing the IAP from central.. too, too many steps. I just decided to make a change to the WLAN>Security from WPA3 to WPA2, and it's good to go for that client device. I'll have them upgrade to WIN 11 in support of upgraded NIC drivers/perhaps support for OWE/WPA3.. that's a maybe without having the intel AX210.. Thanks
