Dear,
What is the best practice procedure to merge two existing IAP clusters managed by Aruba Central without having a lot of reconfiguration and downtime?
Our situation:
Two IAP clusters (UAP-500 series) managed by Aruba Central in two separated VLANs (e.g. VLAN X, VLAN Y). VLAN X has to disappear, so we have to move all the access points from cluster X to cluster Y.
Is it sufficient to reboot all of the cluster X access points and put them in VLAN Y at the same time? Will the access points smoothly join the new cluster Y, including the access point which had the VC role in cluster X?
Regards
Betreb
