Cloud Managed Networks
Central Wired Client IP's
This thread has been viewed 23 times
  • 1.  Central Wired Client IP's
    Posted Jul 17, 2020 02:32 PM
    I currently have full WLAN and LAN Aruba setup, 3xx series AP VC and multiple 2930F's in central. I have a ubiquiti router doing DHCP, my LAN/WiFi are running the same VLAN. My issue is I see wireless IP's but not wired client IP's. Is there some configuration I need to do for this? Also for client names on devices is there anyway to do some sorta alias rather than just see the MAC of a device if it's unable to pull some sorta hostname? (ubiquiti has this and it's great)
  • 2.  RE: Central Wired Client IP's
    Posted Aug 26, 2020 07:01 PM
    "ip client-tracker" is the AOS-S switch command that is needed. do you have this configured?
  • 3.  RE: Central Wired Client IP's
    Posted Jan 21, 2021 03:56 AM
    Hi! How can you run this command? Tried googling and found the command but command doesn't find "ip"
    What is the command and where should we launch the command to activate ip client tracker for cable devices?
    Thanks!
  • 4.  RE: Central Wired Client IP's
    Posted Jan 21, 2021 05:45 PM
    currently there is no WebUI knob for "ip client-tracker" in Aruba Central.
    It is only available if you are managing the LAN switches using template groups.
