I have two independent controllers each running as master within the same LAN. (I know crazy right)
My question is this. Can I still use centralized license feature so they can share licensing?
If so how would you config it?
Yes.
Please feel free to read the Centralized Licensing Chapter, if you have not already here: http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/New_Licenses/Multi__Network.htm?Highlight=centralized licensing
OK.. yeah pretty simple.
enable centralized lic on each controller by hitting the little check mark.
on just one of the controllers put in the other controllers IP address in the License Server IP field
save config...
wait about 15 seconds.....
poof it's working.
Centralised licensing is an independent feature. you just need to enable centralised licensing and make one of the controllers as licensing server so that it can manage the pool.
Please feel free for any further help on this.
