Centralized Licenses - RFProtect Bug or Restricting Access
  • 1.  Centralized Licenses - RFProtect Bug or Restricting Access
    Posted Aug 13, 2013 08:34 PM
    Running 6.3.0.1 with redunant M3 Masters and a mix of 10 M3/7240 locals.
    Not sure this is a feature, or a bug I should put a case in about.
    We have a Centralized license server setup for the past month and it's been
    working fine and we recently moved more (750) WAPs to a controller then it had
    local licenses (512) and the centralized pool provided the extra number and everything
    was fine.
    I recently activated a handful (16) RF Protect licenses to the Master for our
    occasional need of the Spectrum Analyizer feature.  The Master added them
    all to the central pool, then oddly each local controller took 16 RF licenses and
    our total usage went to 160, even though we only have 16 ?? (We're not running
    any configuration that would require RF licenses to my knowlege)
    The counting of RF licenses was strange, but today we re-provisioned all of
    the WAPs on a controller, but only 528 WAPs (upto it's local license count
    +16) got licensed, the other WAPs refused to activate their radios.  Only
    after I removed the 16 RF licenses on the Master, was the local controller able
    to license all the remaining WAPs.  (remember they were all working prior to being
    rebooted)
    So if this is a feature, is there a way I can keep the RF licenses on the Master
    BUT NOT become part of the centralized license system?
    thanks
    mike
  • 2.  RE: Centralized Licenses - RFProtect Bug or Restricting Access
    Posted Aug 21, 2013 08:47 AM
    To close this loop for anyone considering Centralized Licensing.  Since AP/PEF/RF licenses all
    have to maintain the same count, this limitation now has to be extended to the entire license pool
    if running centralized licensing.
    If you have 1000/1000/0  AP/PEF/RF licenses in your pool and join a controller with 8/8/8, your pool
    will be restricted to only 8 AP/PEF licenses.  Your local controllers can still serve out whatever number
    of local licenses they have, but if they need more from the central pool, the limits above will be enforced.
