Centralized Licensing
  • 1.  Centralized Licensing
    Posted Aug 11, 2017 07:18 AM
    I have a question about the "Centralized Licensing".
    I have 1 Master controller, which is license server, and two Local controllers as license clients with a license pool of 32 ap licenses.
    The Master controller (license server) fails and then I add a new 8 ap license to the first Local controller.
    What would happened with the new installed license?
  • 2.  RE: Centralized Licensing
    Posted Aug 11, 2017 07:39 AM
    If your licensing master fails, you have 30 days to replace it before the centralized licenses stop working. Any licenses installed on a physical controller will work in perpetuity on that controller if the centralized licensing master is inaccessible.
  • 3.  RE: Centralized Licensing
    Posted Aug 11, 2017 07:56 AM
    Hi Colin,
    thanks for your  quick answer.
    So the 8 ap license I have installed on the first local controller, after the license server failed, could only be used by this local controller?
    The second local controller can not used this 8 ap license, he only uses the centralized licenses for 30 days, right?
    If the license server is reachable again, would he add the 8 ap license to the centralized license pool?
