Network Management
Centralized Licensing enabled
  • 1.  Centralized Licensing enabled
    Posted Jan 03, 2017 07:31 AM
    We have recently enabled centralised licensing as we installed a new controller. and I need some clarification on how this works with our existing controllers.
    We have a master/local controller environment.
    When we installed the existing controllers, we installed AP licenses on each of the controllers. This would allow a specific number (e.g. 128) APs per controller. We installed a new controller and with the new licensing model, enabled centralised licensing on the master controller. We installed a 128 license on the master controller.
    Are these new licenses available to all controllers or just the new controller? Or will all controllers make use of the centralised licensing?
    Roy
  • 2.  RE: Centralized Licensing enabled
    Posted Jan 03, 2017 07:37 AM
    This licenses will be shared with all controllers if those are not embedded licenses , read this article to verify
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-configure-and-verify-centralized-licensing-in-a-master/ta-p/187208
    Get Outlook for iOS
  • 3.  RE: Centralized Licensing enabled
    Posted Jan 04, 2017 04:09 AM
    That's great. It helps a lot. Thanks.
  • 4.  RE: Centralized Licensing enabled
    The controllers will share applied PEF licenses when centralized licensing is enabled.
