Centralized Licensing Scenario question
  • 1.  Centralized Licensing Scenario question
    Posted Feb 18, 2014 05:43 AM
    I have a question regarding Centralized Licensing.
    At present we have a controller in our data center that manages Rap access.  We would like to put another controller in our other data center as a failover box.
    It is my understanding that if we make the new controller the licensing master and the original box a licensing client of this then the licenses raps will still work on the original box with the correct licenses but in event of failure, once the heartbeat has failed 3 times then the licenses will be available on the new box allowing the Raps to connect to this instead.
    Am I correct in my understanding?
  • 2.  RE: Centralized Licensing Scenario question
    Posted Feb 18, 2014 05:54 AM
    You can definitely do this.
    Are you planning to VRRP or LMS ?
    Is this a Master/Local scenario ?
