Centralized licensing topology Master / Backup (OS 6.3.1)
  • 1.  Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 05, 2014 09:33 AM
    Hello
    I have two 3600 controller configured in Master / Backup thanks to VRRP.
    I owns licenses for only one controller, these licenses are enabled on the Master for the management of access points.
    Do I only activate the "Centralized-licensing-enable" function to ensure that my Master Controller provides its licenses Controller Backup in case of failure of the Master?
    I also turn this feature on the Backup, am I right?
    Laetitia,
    PS: Do not speak English well, I went through the Google translator ...
    #3600
  • 2.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 05, 2014 09:39 AM
    @laetitia wrote:
    Hello
    Laetitia,
    If you  already have a master/backup master configured, you only need to Activate the "centralized-licensing-enable" function on the master.  It will be enabled automatically on the backup master AND the local controllers.  Just make sure that you click on "save configuration" or type "write mem" after you execute that, so that the locals and the backup master can get the configuration change.
  • 3.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 05, 2014 09:57 AM
    Thank you for your quick response!
    I enable this function (Centralized-licensing-enable) on both controllers (master and backup), is it a problem?
    Of course I made a backup (save configuration) after each configuration change ...
  • 4.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 05, 2014 10:09 AM
    You should be ok.
  • 5.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 07, 2014 07:39 AM
    Master Backup is compulsory for centralized licensing ? Can't we do that if you we have only two controller's configured in VRRP mode where one is active and secondary is redundant ?
  • 6.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 20, 2014 02:21 PM
    We have this architecture there precisely: just two controllers in Master / Backup thanks to VRRP. I do not have a Local Controller.
    All my AP is managed by the master.
    Tomorrow, I will test the centralized licensing and especially check my AP continue to operate after you have disconnected the VRRP-Master.
    If all goes well, the AP (normally managed by the VRRP-Master) should be managed by the VRRP-Backup (now Master).
    In fact, I can not quite understand how the VRRP-backup recovers licenses if the VRRP-Master (which has licenses) is no longer on the network ... If someone can explain to me, just for my knowledge base ....
  • 7.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Jan 21, 2014 01:52 AM
    Please share your experience after testing.
  • 8.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 26, 2014 06:05 AM
    laetitia how did this all work out for you?
  • 9.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 26, 2014 06:30 AM
    Sorry, I completely forgot and post the results of my test.
    It went great! I only lost 2 ping when I turn off my main controller.
    My controller backup then took control of my AP though I have no license installed on it: virtualization licensing works perfectly well.
  • 10.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 14, 2017 08:08 AM
    I have the exact same situation here ... With 2 master controllers, but when I shut down my master one, the backup is becoming the new master but the licence is not copied to the standby, and my AP's are lost ...
    I just enabled centralized license feature like you did.
    Do I have a way to verify my config ?
    I probably missed something ....
  • 11.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 14, 2017 08:31 AM
    You need to run these commands on the backup controller when it becomes the master.
    show license aggregate
    show license server-table
    show license client-table
    show license-usage client
    show license-usage ap
     It is possible that you do not have master redundancy configured properly.  On the existing master, you should type "show switches" to see if you see the standy switch.
  • 12.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 14, 2017 08:37 AM
    Here is the config of the standby when it becomes active :
    (GRBWLC02) #show license aggregate
    Aggregate License Table
    Hostname IP Address AP PEF RF Protect xSec Module ACR WebCC Last update (secs. ago)
    GRBWLC02 172.16.100.3 0 0 0 0 0 0 13
    Total AP License Count :0
    Total PEF License Count :0
    Total RF Protect License Count :0
    Total XSEC License Count :0
    Total ACR License Count :0
    Total WebCC License Count :0
    (GRBWLC02) #show license server-table
    License Server Table
    Service Type Aggregate Lic. Used Lic. Remaining Lic.
    Access Points 62 0 62
    Next Generation Policy Enforcement Firewall Module 62 0 62
    RF Protect 0 0 0
    xSec Module 0 0 0
    Advanced Cryptography 0 0 0
    WebCC 0 0 0
    (GRBWLC02) #show license client-table
    Built-in limit: 0
    License Client Table
    Service Type System Limit Server Lic. Used Lic. Contributed Lic. Remaining Lic.
    Access Points 256 0 0 0 0
    Next Generation Policy Enforcement Firewall Module 256 0 0 0 0
    RF Protect 256 0 0 0 0
    xSec Module 4096 0 0 0 0
    Advanced Cryptography 4096 0 0 0 0
    WebCC 256 0 0 0 0
    (GRBWLC02) #show license-usage client
    License Clients License Usage
    Hostname IP Address AP Lic. Used PEF Lic. Used RF Protect Lic. Used xSec Lic. Used ACR Lic. Used WebCC Lic. Used Last update (secs. ago)
    GRBWLC02 172.16.100.3 0 0 0 0 0 0 8
    172.16.100.2 0 0 0 0 0 0 24
    Total AP Licenses Used :0
    Total PEF Licenses Used :0
    Total RF Protect Licenses Used :0
    Total XSEC Licenses Used :0
    Total ACR Licenses Used :0
    Total WebCC Licenses Used :0
    Total no. of clients :2
    (GRBWLC02) #show license-usage ap
    AP Licenses
    Type Number
    AP Licenses 62
    PEF Licenses 62
    Overall AP License Limit 62
    AP Usage
    Type Count
    Active CAPs 0
    Standby CAPs 0
    RAPs 0
    Remote-node APs 0
    Tunneled nodes 0
    Total APs 0
    Remaining AP Capacity
    Type Number
    CAPs 62
    RAPs 62
    But it looks like the AP's are still not coming back...
  • 13.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 14, 2017 08:48 AM
    What does "show log system 50" and "show ap database" say?
  • 14.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 02:55 AM
    Nothing special on the log system 50, that's why I cleared the config and did it again and this time this is working.
    When the primary goes down, I have 30 days to replace it , right ?
  • 15.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    MVP EXPERT
    Posted Feb 16, 2017 03:30 AM
    Hey, a client controller retains its licensing information for 30 days after it loses contact with the licensing server, if the client reboots at any time during this 30-day window, the window will restart, and the client will retain its information for another 30 days.
  • 16.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 03:51 AM
    Oh really ? That's strange but that looks cool, thank you.
  • 17.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 07:01 AM
    I have 4 interfaces on the master WLC, but when it goes down, the standby doens't have these interfaces, it only has the management interface, so how the client traffic can still work ?
    AL
  • 18.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 08:26 AM
    VLANs, ip addreses and interfaces are not replicated in the global configuration and must be configured manually on the backup controller.
  • 19.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 09:41 AM
    Alright, with a different IP address or the same ?
    I mean, let's say we have on the WLC 1 :
    VLAN 100 : 172.16.100.1
    VLAN 101 : 172.16.101.1
    Do I have to configure on the WLC 2 :
    VLAN 100 : 172.16.100.1 or .2 ?
    VLAN 101 : 172.16.101.1 or .2 ?
  • 20.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 09:58 AM
    Different.  They must be unique.
  • 21.  RE: Centralized licensing topology Master / Backup (OS 6.3.1)
    Posted Feb 16, 2017 10:13 AM
    Ok thank you, I will correct that
