Certificate based authentication on Controller
  • 1.  Certificate based authentication on Controller
    Posted Oct 12, 2015 04:56 AM
    i wanna configute a ssid with local check if the client certificate machtes the local controller certifiacte. So i try to list here my steps, because it didn't work :)
    6.4.3.3
    1) Create a Controller Cert with CSR
    2) Install Server and RootCA Cert
    3) Create L3 Dot1x Auth Profile (eap tls) and Ca-Cert and Server Cert checked in advanced (Termination)
    4) Create AAA Prof with 802.1x Authentication -> Step3 Profile  (Mac n/a, Servergroup n/a)
    5) Vap Profile with AAA using Step4
    In My Windows 8.1 Client i create a SSID-Prof with same Settings like my other one SSID with Cert -> Sends Radius Requests to external AAA Server) so i think that is not the problem.
    If i activate security debug level - i only see some crypric stuff if i want to log in - but no real good text...
    So is anyone out there that have configured a local termination that is working ? I checked the community but i dind't find any real guide or information to this issue.
    Thanks for Feedback
  • 2.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 05:40 AM
    Additon Info:
    if i reconfigure a SSID with my AAA Profile it pops up with that error:
    Error processing command 'wlan virtual-ap "test111" ssid-profile "ssid_temp_Certtest"':Error: Server Group needs to be configured in dot1x/aaa profile "802.1x_Cert_Temp_Cert/AAA_Certificate" to support opmode "wpa2-aes" in ssid profile "ssid_temp_Certtest"
    maybe this error expain my Problem:
    A VAP Profile needs with WPA2 a Servergroup. But with local Termination and TLS i didn't have a Server :-( If i create a  local Server Group in the controller it checks the certificate Username agains local DB :-(  But i only want a Certificate check and not a username check ... so maybe this is the point witch iam looking for.
  • 3.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 07:17 AM
    You can create a server group that only has the internal database, but in the 802.1x profile, DO NOT enable "Check Certificate Common name against AAA server"  :  http://community.arubanetworks.com/t5/Controller-Based-WLANs/With-EAP-TLS-how-to-check-user-certificate-common-name-against/ta-p/215343
    The problem is that the WPA2-AES 802.1x setup requires that you put a radius server in the server group attached to the AAA profile, even if you don't use it.
    For your error messages, you should type "show auth-tracebuf" and see the radius messages going back and forth to see what could possibly be the problem.
  • 4.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 08:17 AM
    i unchecked that AAA Box (last checkbox) - thanks so far :) and entered a default AAA Server in a server group but it didn't work:
    Here is the Output:
    Oct 12 14:07:15 station-up * 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60 - - wpa2 aes
    Oct 12 14:07:15 station-term-start * 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60 10 -
    Oct 12 14:07:15 eap-term-start -> 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60/802.1x_Cert_Temp - -
    Oct 12 14:07:15 station-tls-alert * 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60/802.1x_Cert_Temp 48 2 failure
    Oct 12 14:07:15 station-term-end * 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60/802.1x_Cert_Temp 1 - failure
    Oct 12 14:07:15 eap-failure <- 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60/802.1x_Cert_Temp - 4
    Oct 12 14:07:15 station-down * 34:02:86:b4:91:b9 ac:a3:1e:ee:07:60 - -
    So i currently have a Machine Certificate for my Controller and a User Cert on my Notebook - as written above: Client works with Windows Radius AAA forwarding.
    Maybe i need a different Windows config with this local certificate ?
  • 5.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 09:39 AM
    Also, you need do create a client certificate to use for authentication. You can't use a server certificate for client auth.
    Tim
  • 6.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 09:47 AM
    Good info.. checked the Cert on the controller - only two attributes set and no Client Authentification.... back to the CA Admin :) Hope the new one works ^^
  • 7.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 09:49 AM
    You'll still need the server certificate on the controller. The client certificate is installed on the device.
    Tim
  • 8.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 09:55 AM
    Sure but i think my actually has no permission to check Clients. Dunno witch statement is needed here but i think it didn't work with only Digital Signature, Key Encipherment (a0) and Server Authentication (1.3.6.1.5.5.7.3.1) as Enhanced Key Usage.
  • 9.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 09:57 AM
    Right. There are two certificates. The only one that will work on the client is a client certificate. It's a different type of cert that gets created.
    Tim
  • 10.  RE: Certificate based authentication on Controller
    Posted Oct 12, 2015 10:09 AM
    Hi sorry, i have two different Types: client-certificate with the Client-Auth Usage set and a Server Cert without any Client-Auth. I think thats the reason why it dont work.
    If i get that running i will create a guide for other users :) I think no one has a complete step by step config for this situation. And in fact that the controller works with CRL Aruba needs a good Guide :-)
    Back here, when i got my new Controller Cert (takes some days...)
