Certificate error with Aruba IAP105
  • 1.  Certificate error with Aruba IAP105
    Posted Nov 24, 2015 10:28 PM
    Hi Support,
    We are trying to configure Aruba Instant AP 105 with LDAP authentication. I can successfully connect to my wireless profile from my mobile but it couldn't connected from my laptop. Error message as shown in below. Please advise how to import certificate into our server. Otherwise is there anyway to import our AD cert into IAP?
    Please kindly advise. Thanks in advanced!!
    Chan
  • 2.  RE: Certificate error with Aruba IAP105
    Posted Nov 24, 2015 10:30 PM
    That is a normal part of the EAP process. Click "Connect".
  • 3.  RE: Certificate error with Aruba IAP105
    Posted Nov 24, 2015 10:34 PM
    Hi Tim,
    When I click 'connect' it will be ended with below error.
  • 4.  RE: Certificate error with Aruba IAP105
    Posted Nov 24, 2015 10:36 PM
    Looks like you're using Windows 7 which does not support EAP-GTC natively.
    You have two options:
    1. Stand up a RADIUS server (preferred)
    2. Install an EAP-GTC supplicant: https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/114/Default.aspx
  • 5.  RE: Certificate error with Aruba IAP105
    Posted Nov 25, 2015 09:09 PM
    Thanks Tim!
    The issue has been solved.
    Chan
