Certificate Errors
  • 1.  Certificate Errors
    Posted Nov 07, 2012 07:17 AM
    I've installed a Comodo certificate on my Aruba 3600 for WebUI and Captive Portal.  It works ok when accessing the WebUI in IE but in Firefox I get the error:
    aruba-master.xyz.com uses an invalid security certificate. The certificate is not trusted because no issuer chain was provided. (Error code: sec_error_unknown_issuer)
    That's ok as I can just add an exception but the real issue is with the Captive Portal.
    With Android I can accept the error but Safari gives the error:
    Cannot Verify Server Identity: Wi-Fi cannot verify the identity of "aruba-master.xyz.com"
    and won't let me go any further.  I've installed the intermediate certificates that came with the server certificate AddTrustExternalCARoot and ComodoSSL as IntermediateCA types with PEM as the Certificate Format but the problem persists.
    I fond another user with the problem but no apparent solution:
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Thawte-server-certificate-issue/td-p/6959
    Anybody got any ideas?
    #3600
  • 2.  RE: Certificate Errors
    Posted Nov 07, 2012 02:20 PM
    hi RonanOC,
    please check the following option in the Captive Portal Authentication Profile:
    Use HTTP for
    authentication
    it would help you.
    good luck.
  • 3.  RE: Certificate Errors
    Posted Nov 08, 2012 04:48 AM
    Hi Abi,
    Yes that would stop the error occurring but I need to use https to encrypt the traffic.  I found the solution.  You need to create a certificate bindle with all the certs and upload that.  It is working now.
    https://support.comodo.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=1209
