Certificate for Instant AP for Guest Portal on Aruba Central
This thread has been viewed 28 times
  • 1.  Certificate for Instant AP for Guest Portal on Aruba Central
    Posted Jun 21, 2021 09:38 PM
    Hi
    I like to ask about installing the public certificate for Instant AP that will have guest captive portal hosted in Aruba Central. I understand if the GCP is hosted in ClearPass, I can use either public wildcard or a public certificate with specific CN and ensure the correct configuration on ClearPass Guest. With Aruba Central, can I have a public certificate with specific CN installed into the Instant cluster so that when Aruba Central guest redirects the user back, it does not display unsecure page?
    Thanks.
    Simon Lim
  • 2.  RE: Certificate for Instant AP for Guest Portal on Aruba Central
    Posted Jun 21, 2021 10:57 PM
    Sorry, post in wrong discussion group.
    Cheers.
    Simon Lim
  • 3.  RE: Certificate for Instant AP for Guest Portal on Aruba Central
    Posted Jun 22, 2021 08:30 AM
    Hi Simon168,
    Yes, you can either use a Wildcard Certificate or a named Certificate for the Instant Cluster Guest Portal.
    You will want to configure the Clearpass Guest Portal with the name of the certificate.
    - For WebLogin Pages, the field is labeled *Address
    - For Self-Registration Pages, the field is labeled *IP Address
    - Both page types have a label "Enter the IP address or hostname of the vendor's product here." for these fields.
    If using a named Certificate put the full FQDN / CN name in this field.
    If using a Wildcard Certificate, use the name - captiveportal-login.domain.name (domain.name being your own Domain name of course.).
    Philip Wightman, ACEX (AMFX) #69. Aruba Partner Ambassador
  • 4.  RE: Certificate for Instant AP for Guest Portal on Aruba Central
    Posted Jun 24, 2021 11:30 PM
    Cheers. Thanks very much.
    Simon Lim
