"certificate is not a CA " error while uploading the signed certificate for ClearPass OnBoard
  • 1.  "certificate is not a CA " error while uploading the signed certificate for ClearPass OnBoard
    Posted May 21, 2015 07:54 AM
    I have raised a CSR for clear passs as a intermidaite server in onboaring. Got signed from the root CA and when I am trying to install the signed certifiate it is showing me the error "certificate is not a CA". PFA error.
  • 2.  RE: "certificate is not a CA " error while uploading the signed certificate for ClearPass OnBoard
    Posted May 21, 2015 08:56 AM
    Please take a look at the tech note here - https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=7961
    Look for Onboarding with ADCS.
    I assume that you want some other CA to issue the certs?
  • 3.  RE: "certificate is not a CA " error while uploading the signed certificate for ClearPass OnBoard
    Posted May 22, 2015 01:03 AM
    Here I am configuring my clear pass as a intermitdiate server for the onboarding devices to issue the certificate. So I have raised a CSR in clear pass onboarding certificate authority and got it signed from my root CA in "p7b" format as per the format mentioned in the clear pass. when I am trying to upload the signed certifcate from root CA to clear passs onboard I am seeing the error "certificate is not a CA " .
    Kindly help.
