Certificate Revocation list on Clear pass
  • 1.  Certificate Revocation list on Clear pass
    Posted Mar 28, 2017 09:28 PM
    Once we add the CRL on the clear pass Administration--->Certificate-Revocation list -->URL
    May i know where we can view the Serial numbers of certificates which are revoked on the CPPM?
    and i have the EAP-tls service is there anything else i need to confgure to do CRL check?
  • 2.  RE: Certificate Revocation list on Clear pass
    Posted Mar 28, 2017 09:48 PM
    You would need to look at the CRL contents directly via the URL. We do not have a way to view the contents in the GUI.
  • 3.  RE: Certificate Revocation list on Clear pass
    Posted Mar 28, 2017 10:28 PM
    So i need to use the URL put on a web browser and able to see the Serail numbers of Certificates.
    Is my understanding is correct?
  • 4.  RE: Certificate Revocation list on Clear pass
    Posted Mar 28, 2017 10:34 PM
    Yes, or look at your Certificate Authority. Raw CRLs and OCSP responses were never really designed for human consumption :)
  • 5.  RE: Certificate Revocation list on Clear pass
    Posted Mar 28, 2017 10:37 PM
    Thanks a lot
  • 6.  RE: Certificate Revocation list on Clear pass
    Posted Jul 05, 2017 07:50 AM
    After you configured the CRL, did you then have to reference this in your service? I'm reviewing our EAP-TLS service but can only see references to OSCP configuration?
    With this in mind, is it the case that once the CRL is configured that the EAP-TLS service inherently uses this CRL without it being explicitly configured?
  • 7.  RE: Certificate Revocation list on Clear pass
    Posted Jul 05, 2017 08:02 AM
    No, it just needs to be defined. OCSP should be used with EAP-TLS though.
  • 8.  RE: Certificate Revocation list on Clear pass
    Posted Jul 05, 2017 09:27 AM
    Agree regarding the OCSP comment, we are being given a steer by our internal PKI team to use a CRL :(
    Thanks for confirming.
