Certificate Signing Request with ECDSA P-384 and SHA-384
  • 1.  Certificate Signing Request with ECDSA P-384 and SHA-384
    Posted Feb 12, 2017 11:18 AM
    Is it possible to create a Certificate Signing Request for ECDSA P-384 and SHA-384 with the Aruba Mobility Controller 72xx series?
    It appears to be limited to SHA-256 as a maximum.
  • 2.  RE: Certificate Signing Request with ECDSA P-384 and SHA-384
  • 3.  RE: Certificate Signing Request with ECDSA P-384 and SHA-384
    Posted Feb 12, 2017 02:22 PM
    Thank you for the reply but from my understanding, that may be SHA2 but not at 384. If you generate a CSR with that, I think you will find it is SHA-256. I could be wrong, it may be I'm running an older version of code or have a licensing issue. I'm new to Aruba.
    Judging by the Open SSL documentation, it should list ecdsa-with-SHA384.I think Aruba uses Open SSL due to the similarity in the command line.
    Here is a link that discusses the Open SSL capability.
    http://stackoverflow.com/questions/16818014/generate-csr-with-secp384r1elliptic-curve-key-and-sha384-hash-signature
    Being new to Aruba, I don't know of any way to get this rone.
  • 4.  RE: Certificate Signing Request with ECDSA P-384 and SHA-384
    Posted Feb 12, 2017 02:25 PM
    In most cases, it's recommended to do the CSR on an external server so you can back up the private key and/or use the certificate on your other controllers.
  • 5.  RE: Certificate Signing Request with ECDSA P-384 and SHA-384
    Posted Feb 12, 2017 03:08 PM
    Agreed,
    Just generate your own CSR offline.
  • 6.  RE: Certificate Signing Request with ECDSA P-384 and SHA-384
    Posted Feb 13, 2017 01:25 AM
    Thanks, got it.
    On a different device:
    Create keys as exportable
    Create CSR
    Apply for certificate using CSR
    Import keys on controller
    Import certificate on controller
    Show some care when doing this, certificates are tied to DNS.
