certificate warning clearpass using http
  • 1.  certificate warning clearpass using http
    Posted May 19, 2017 09:49 AM
    Hello i want to use the captive portal but i dont want to  get the certificate warning, ill use http, and i know it goes on cleartext the password and user.
    Anyways I have set it up that on clearpass on the selftregistration  on
    Secure Login im putting send clearpass password cleartext http
    on the controller on the captive portal authentication i put the checkbox i put the check on it also on the  login page i put http instead of https for the url
    and when i use the captive portal im getting redirected but i get the certificate warning
    Also i tried this
    http://community.arubanetworks.com/t5/Technology-Blog/Captive-Portal-why-do-I-get-those-certificate-warnings/ba-p/268921
    and i tried deleting the https rule that redirect but when i do that when iuse the captive portal i get stuck when i try to use a https page like google to po up the captive portal... if i use a page that use http then its okay it works but users will try to use google or something like that so this does not work for me...
    I also see that the someone posted a mesage in that tread that noone asnwer to seems to be the same problem
    TIM, someone!  help? :(
    Cheers
    Carlos
  • 2.  RE: certificate warning clearpass using http
    Posted May 19, 2017 11:18 AM
    Hi Carlos,
    In Home » Configuration » Authentication page, uncheck the security box.
    Security:
    Require HTTPS for guest access
    If checked, HTTP access by guests will be redirected to use HTTPS instead.
    Pavan
    If my post addrresses your query, give kudos:)
  • 3.  RE: certificate warning clearpass using http
    Posted May 19, 2017 03:53 PM
    i still get the certificate error....
  • 4.  RE: certificate warning clearpass using http
    Posted May 19, 2017 03:55 PM
    Are you getting a certificate error when you go to a non-secured site like ebay.com?
  • 5.  RE: certificate warning clearpass using http
    Posted May 19, 2017 03:57 PM
    its when i got to a secure page for example google.com
  • 6.  RE: certificate warning clearpass using http
    Posted May 19, 2017 04:03 PM
    On clearpass this is also unchecked
    Require HTTPS for guest access under Authentication Settings
  • 7.  RE: certificate warning clearpass using http
    Posted May 19, 2017 04:08 PM
    The only way to prevent that would be to remove HTTPS redirection in your user-role.
  • 8.  RE: certificate warning clearpass using http
    Posted May 19, 2017 04:21 PM
    If you mean deleting this rule
    IPv4 user any svc-https dst-nat 8081 Low
    I already did it and when i do that the https pages wont open...
    Cheers
    Carlos
  • 9.  RE: certificate warning clearpass using http
    Posted May 19, 2017 04:23 PM
    That’s correct. There is no way to avoid certificate warnings when navigating to an HTTPS page. That’s the whole point of the certificate warning in the first place.
  • 10.  RE: certificate warning clearpass using http
    Posted May 19, 2017 04:26 PM
    That works if the captive portal is the controller....
    It doesnt work if the captive portal is the clearpass...
    So there is no way to do this with the clearpass? even using http only?
    It just that i find odd that you can do it with controller but not with clearpass..
  • 11.  RE: certificate warning clearpass using http
    Posted May 20, 2017 11:22 AM
    Tim is there is any way that with the clearpass i dont get the certificate error when the user goes to the web browser and go for an https like google to get the captive portal?
    If there is no way is there any documentation we can use to show that is not possible?
    Cheers
    Carlos
  • 12.  RE: certificate warning clearpass using http
    Posted May 20, 2017 12:59 PM
    Hello Tim
    I have been reading about this topic today and i reach to this conclutions which i would like to know if they are correct
    1-When the user navigates to a https website like google there is no way to NOT get the certificate warning because when the user goes to https://www.google.com the client is expecting the certificate of google and instead of that get the certificate of the controller or clearpass and even if you put a public certificate he is not expecting that certificate and we end up with the certificate error
    2-When accessing HTTP there is no problem becuase we are not expecting any cert on that website, and when we get redirected to the captive portal IF we do not have a public certificate, we will get a certificate error(becuase the cilent does not have the root certificate of the controller) If the controller or clearpass has  a public certificate THEN we will not get any certificate error of any kind
    3-I bealive i can use this article as an explanation of whats happening
    is all this correct? Tim?
    Cheers
    Carlos
  • 13.  RE: certificate warning clearpass using http
    Posted May 21, 2017 10:54 AM
    Looks correct.
