I am trying to change the below certificates in a master redundancy Aruba setup due to the relocation of the two controllers from one location to another. This relocation requires changing the Hostname and any other old location related names to the new name. The certificates are holding the name of the old location so accordingly, we need to change it also.
Appreciate it if you guide me on how I can do this and where to request the new certificate with the new name to be valid for use, or just changing the name in the configuration will be enough. I am new to the Aruba world so please help me.
below is the current configuration sample from the master:
web-server profile
switch-cert "xxxwc01-new"
captive-portal-cert "xxxwc01-new"
hostname "xxxwc01"
crypto-local pki TrustedCA Rock-CA-2018 Rock-CA.cer
crypto-local pki ServerCert xxxwc01-new xxxwc011_Rock_local.pfx
crypto-local pki rcp "Rock-CA-2018"
revocation-check none
aaa authentication dot1x "dot1x_prof-hhh"
ca-cert "Rock-CA-2018"
server-cert "xxxwc01-new"
Note:
The new certificate name will be inherited from the new location name as per the below:
web-server profile
switch-cert "YYYwc01-new"
captive-portal-cert "YYYwc01-new"
hostname "YYYwc01"
crypto-local pki ServerCert YYYwc01-new YYYwc01_Rock_local.pfx
aaa authentication dot1x "dot1x_prof-aww78"
server-cert "YYYwc01-new"
Thanks in Advance!
