Change Air Monitor mode to AP mode
This thread has been viewed 43 times
  • 1.  Change Air Monitor mode to AP mode
    Posted Jan 09, 2018 03:26 AM
    Hi everyone,
    I have an 228 AP is provisioned with 7210 Controller running 6.5.1.4 OS.
    My Ap only working as Air Monitors mode and i I couldn't find the way to change it from Air Monitor mode to AP mode.
    Any one can show me step by step to fix this issue ?
    Thanks for help.
  • 2.  RE: Change Air Monitor mode to AP mode
    Posted Jan 09, 2018 03:43 AM
    Is AP license install?
  • 3.  RE: Change Air Monitor mode to AP mode
    MVP EXPERT
    Posted Jan 09, 2018 04:09 AM
    The AP appears to have been provisioned in the "default" ap-group, which I suspect is using AM-Mode in the Radio profiles. You will need to either change the AP mode within Radio Profiles or re-provision the AP to a different ap-group where the AP's are configured to use AP mode.
    http://community.arubanetworks.com/t5/Wireless-Access/How-to-change-am-mode-to-ap-mode/td-p/17526
  • 4.  RE: Change Air Monitor mode to AP mode
    Posted Jan 09, 2018 05:09 AM
    Hi zalion,
    You're right. My 228 AP have been provisioned in the "default" ap-group, but i have a  question that why after provision, only 228 model have been changed to Air Monitor while 325 model still is AP mode
    Thanks for help.
  • 5.  RE: Change Air Monitor mode to AP mode
    MVP EXPERT
    Posted Jan 09, 2018 05:15 AM
    Are they both in the default ap-group? What is the regulatory domain of of the AP228 set on the default group? Are you able to provide the output of the below?
    #show ap database
    #show log all | include XXXX (wired MAC of AP)
  • 6.  RE: Change Air Monitor mode to AP mode
    Posted Jan 15, 2018 11:56 PM
    Hi Zalion,
    Sorry for lately reply,
    They both in the default group. I  don't clear about "regulatory domain" but hence is output:
    #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    20:a6:cd:cc:45:7e default 325 172.16.0.103 Up 15m:39s 2I 172.16.0.254 0.0.0.0
    b4:5d:50:c8:d2:2c default 228 172.16.0.104 Up 17m:24s 2 172.16.0.254 0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
    I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
    X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
    c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
    i = Indoor; o = Outdoor
    M = Mesh node; Y = Mesh Recovery
    Total APs:2
    #show log all | include b4:5d:50:c8:d2:2c
    Jan 16 11:31:20 nanny[2836]: <303022> <WARN> |AP b4:5d:50:c8:d2:2c@172.16.0.104 nanny| Reboot Reason: AP rebooted Wed Dec 31 16:05:19 PST 1969; DHCP timed out
    Jan 16 11:34:16 KERNEL(b4:5d:50:c8:d2:2c@172.16.0.104): [ 307.768435] enabling the USB interface
    Jan 16 11:35:12 stm[4091]: <402000> <4091> <WARN> |stm| AP b4:5d:50:c8:d2:2c radio 0: No valid channels; entering air monitor mode.
    Jan 16 11:35:12 stm[4091]: <402000> <4091> <WARN> |stm| AP b4:5d:50:c8:d2:2c radio 1: No valid channels; entering air monitor mode.
    #show log all | include 20:a6:cd:cc:45:7e
    Jan 16 11:31:46 nanny[2222]: <303022> <WARN> |AP 20:a6:cd:cc:45:7e@172.16.0.103 nanny| Reboot Reason: AP rebooted Wed Dec 31 16:05:04 PST 1969; DHCP timed out
    Jan 16 11:33:35 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 160.309653] Disabling USB power
    Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976038] Enabling USB power
    Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976069] Enabling eth1 due to power change [power profile 1]
    Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976601] Resetting spectral chainmask to Rx chainmask
    Jan 16 11:33:38 KERNEL(20:a6:cd:cc:45:7e@172.16.0.103): [ 163.976694] Resetting spectral chainmask to Rx chainmask
    Thanks for help
  • 7.  RE: Change Air Monitor mode to AP mode
    MVP EXPERT
    Posted Jan 16, 2018 01:39 AM
    Thanks, if you don’t know the regulatory domain of the AP (you’ll be able to find this under the sap-group) could you let us know the country where the AP is installed?
    Please also run the following command
    show ap allowed-channels country-code ap-type 325
    Sent from my iPhone
  • 8.  RE: Change Air Monitor mode to AP mode
    Posted Jan 16, 2018 01:49 AM
    Hi Zalion,
    This is output:
    #show ap allowed-channels country-code VN ap-type 228
    Allowed Channels for AP Type 228 Country Code "VN" Country "Vietnam"
    PHY Type Allowed Channels
    802.11g (indoor) None
    802.11a (indoor) None
    802.11g (outdoor) None
    802.11a (outdoor) None
    802.11g 40MHz (indoor) None
    802.11a 40MHz (indoor) None
    802.11g 40MHz (outdoor) None
    802.11a 40MHz (outdoor) None
    802.11a 80MHz (indoor) None
    802.11a 80MHz (outdoor) None
    802.11a (DFS) None
    show ap allowed-channels country-code VN ap-type 325
    Allowed Channels for AP Type 325 Country Code "VN" Country "Vietnam"
    802.11g (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    802.11g (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    802.11g 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    802.11g 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (outdoor) 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    802.11a 80MHz (indoor) 36-48 52-64 100-112 116-128 149-161
    802.11a 80MHz (outdoor) 52-64 100-112 116-128 149-161
    802.11a (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    ==> Refer the output, Does my 228 ap not allowed with any channel and can't use ?
    Many thanks
  • 9.  RE: Change Air Monitor mode to AP mode
    MVP EXPERT
    Posted Jan 16, 2018 02:09 AM
    Can you confirm which DRT you are running? It seems that the 228 in Vietnam is supported from DRT 1.0_61955 onwards.
    Sent from my iPhone
  • 10.  RE: Change Air Monitor mode to AP mode
    Posted Jan 16, 2018 03:23 AM
    Hi Zalion,
    Can u explain to memore detail about the DRT  ? I've never heard it before, and how can i show it ?
    Many thanks
  • 11.  RE: Change Air Monitor mode to AP mode
    MVP EXPERT
    Posted Jan 16, 2018 05:12 AM
    Hey, take a look at the below. This should help
    http://www.arubanetworks.com/techdocs/DRT/Content/ReleaseNotes/Upgrade/DownloadableRegulatoryTable.htm
    Sent from my iPhone
  • 12.  RE: Change Air Monitor mode to AP mode
    Posted Jan 16, 2018 09:52 PM
    Thanks Zalion,
    My DRT version is 1.0_58653, it lower than 1.0_61955. It may be one of the reasons that my ap is moved to AM mode.
    I will upgrate it with new DRT version and hope it work.
    Many Thanks
  • 13.  RE: Change Air Monitor mode to AP mode
    Posted Jan 16, 2018 11:51 PM
    From the output of 228 is not support this.
    Please try to change regulatory domain profile to another country.
    Configuration > Wireless > AP Configuration > AP Group > AP  > Regulatory Domain then you will see Country Code.
    I recommend you to create new AP group and move one of 228 to here then following above.
    Cheer up!!!
  • 14.  RE: Change Air Monitor mode to AP mode
    Posted Jan 17, 2018 01:28 AM
    Thanks all,
    I'm very appreciate your support. I resolved my issue :D
  • 15.  RE: Change Air Monitor mode to AP mode
    Posted Jan 09, 2018 05:54 AM
    Use this command for check compatible of AP model "show ap allowed-channels country-code <country-code> ap-type 228"
