Network Management
Change Airwave IP - fix /etc/sysconfig/network-scripts
  • 1.  Change Airwave IP - fix /etc/sysconfig/network-scripts
    Posted Feb 14, 2019 08:59 AM
    I've just moved the Airwave to a different host (virtual) and I wasn't able to get the networking.
    I've attached the screenshot, but basically It could find the phy(virtual) network adapter on the VM.
    Is there any way to edit the /etc/sysconfig/network-scripts?
  • 2.  RE: Change Airwave IP - fix /etc/sysconfig/network-scripts
    Posted Feb 14, 2019 11:50 AM
    If Airwave version is 8.2.4 or above you would have to contact TAC as it needs to be done from shell. Since its a VM migrated it might be holding the old MAC and the new instance might be having a different MAC. So, we might have to update it and or remove the persistant.d file and reboot the server.
