Change Airwave IP on Controllers
  • 1.  Change Airwave IP on Controllers
    Posted Dec 13, 2019 06:01 AM
    Is there a way to change the Airwave IP address on a 7205 controller?
    I'm running version 8.2.1.1 and the controllers inherited the config from a parent folder.
    Sean
  • 2.  RE: Change Airwave IP on Controllers
    Posted Dec 13, 2019 06:36 AM
    Can you change it at the parent folder?
  • 3.  RE: Change Airwave IP on Controllers
    Posted Dec 13, 2019 06:45 AM
    I'd have to turn it off on the parent folder, which would then turn off airwave monitoring for all controllers and AP's and then change the IP.  I was wondering if there was a way to change it once controller or cluster at a time.
  • 4.  RE: Change Airwave IP on Controllers
    Posted Dec 13, 2019 06:49 AM
    Could you turn it off, push that command, then turn it on with the correct ip address?  Are you migrating Airwave servers or adding a new, different server?
  • 5.  RE: Change Airwave IP on Controllers
    Posted Dec 13, 2019 06:52 AM
    I am added a new one.
    I csn't turn it off at the controller or cluster level, only at the parent folder level.
    Sean
