Change Aruba Controller Hostname
  • 1.  Change Aruba Controller Hostname
    Posted Dec 12, 2016 05:09 PM
    We just deployed 2 Aruba 7205 local controllers.  The hostname for these controllers are showing the default "Aruba7205".  How do I change the hostname to something more meaningful?  If I go through the controller wizard, I have the option to change the hostname, but nothing is changed after I click Finished.  Maybe a CLI option?
    Thanks!
  • 2.  RE: Change Aruba Controller Hostname
    Posted Dec 12, 2016 05:12 PM
    config t
    Hostname yourhostname
  • 3.  RE: Change Aruba Controller Hostname
    Posted Dec 12, 2016 05:14 PM
    >From CLI :
    (LOCAL-CONTROLLER) (config) #hostname "CONTROLLER NAME"
    FROM GUI:
    Configuration > Management > SNMP > Hostname
  • 4.  RE: Change Aruba Controller Hostname
    Posted Dec 12, 2016 05:18 PM
    Thanks for the quick reply!  I knew it was simple...just couldn't find it!
    Thanks again!
