Change Controller Deployment Mode from Branch to Standalone/Master
  • 1.  Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Apr 21, 2016 05:18 PM
    I have a question about a Aruba 7005 Mobility Controller.
    The controller is running OS Version 6.4.4.5
    The controller was accidentally configured as Branch Controller.
    As a result, we're unable to access any of the features.
    What is the process to switch the deployment mode from Branch to Standalone/Master?
  • 2.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Apr 21, 2016 07:23 PM
    You will need to reset it back to default and from the initial wizard select the option of Master
    You can do a write erase from CLI
  • 3.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Apr 21, 2016 09:03 PM
    You will need to reset it back to default so you can select the master option from the initial wizard.
    From CLI you can run the following command "write erase all"
    Sent from Outlook for iPhone
  • 4.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Apr 22, 2016 07:37 AM
    Hi Victor. Thanks for the response.
    Actually, I tried the wipe erase step.
    Unfortunately, due to permissions, it will now allow me to execute command.
    I receive the following message:
    (Aruba7005) #write erase all
    You do not have permission to execute this command.
    (Aruba7005) #
  • 5.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted May 01, 2016 09:20 PM
    You'll need to factory reset it. Run the command write erase and then reload it.
  • 6.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Jun 01, 2017 04:42 PM
    Branch mode won't allow that command. What else can be done?
    Mike
  • 7.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Jun 01, 2017 07:40 PM
    Are you trying to reset the branch controller using smart config to default factory ?
    Get Outlook for iOS
  • 8.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Jun 02, 2017 11:19 AM
    Not using Smart Config. The 7010 branch controller was configured with a static IP address using the full-setup provisioning mode. Now there is no longer a need for a static IP address. I'd ideally like to restart the startup wizard and instead choose the mini-setup provisioning mode.
    I have console access to the 7010. Just can't seem to run many (any) commands on the controller even when in enable mode.
    Mike
  • 9.  RE: Change Controller Deployment Mode from Branch to Standalone/Master
    Posted Jun 02, 2017 12:15 PM
    Actually I think I got it! I was able restart the initial provisioning setup wizard (where you select a provisioing mode) by poking through the LCD Menu on the front of the 7010 and selecting factory default. Pays to read the printed Installation Guide that came with the controller!
    Mike
