Change Controller Interface Config in Disaster Recovery Mode
  • 1.  Change Controller Interface Config in Disaster Recovery Mode
    Posted Feb 06, 2018 10:09 AM
    I'm experimenting with 8.2 and MM and a controller in a VMware environment. I changed the management interface VLAN on the controller and lost network access to it. I went into the controller console and into disaster recovery mode to attempt to put it back the way it was. It takes the commands, but the config doesn't change. What am I doing wrong?
    Robert
  • 2.  RE: Change Controller Interface Config in Disaster Recovery Mode
    Posted Aug 24, 2020 03:00 PM
    I am encountering this same problem with a 7010 controller. Attempting to disable an interface in disaster recovery mode does not work. Interface still shows up / up after sending a shutdown command
