change controller ip on controller and airwave
  • 1.  change controller ip on controller and airwave
    Posted Jun 27, 2016 04:50 PM
    Hi all,
    our 7200 series controller (master/standby) currently has 2 vrrp ips on 2 different subnets/vlans (both routed)
    airwave (monitor only) is connected to the, lets call it "old" vrrp-ip
    our goal is to remove the old vrrp ip together with the vlan, without adding a "new" device to airwave.
    airwave ip and "old" controller ip are in the same subnet (vlan)
    what i already did:
    added second vrrp-ip on new vlan
    changed the default gateway to the new vrrp-ip network.
    changed the aruba-master dns-entry to the new vrrp-ip (all APs are using new VRRP already)
    added the new vrrp-ip to our radius-server for client-auth
    my questions are:
    how to remove the vlan without having to add the device to airwave again?
    we have a visualRF with 120 aps on that controller, i dont want to place them again....
    is there anything else i should be aware of, before removing the vlan with the main ips?
    regards
    Dtwo
  • 2.  RE: change controller ip on controller and airwave
    Posted Jun 28, 2016 12:16 AM
    - change the ip address of the device in Airwave, and it should poll the new ip address without problems
  • 3.  RE: change controller ip on controller and airwave
    Posted Jun 28, 2016 03:30 AM
    Hey Joseph,
    thanks for the reply, but i cannot find the option to change the ip in airwave.
    the device is in "monitor only + firmwareupdates" mode in airwave.
    regards
    Dtwo
  • 4.  RE: change controller ip on controller and airwave
    Posted Jun 28, 2016 06:53 AM
    In Airwave go to AP / Devices, select the folder that  your controller is in. Click on your controller then select the manage tab. You can then change the IP:
    2016-06-28 11_49_26-77.44.121.11 - Remote Desktop Connection Manager v2.2.jpg
  • 5.  RE: change controller ip on controller and airwave
    Posted Jun 28, 2016 08:45 AM
    thanks all.
    works like a charm!
