change controller role from standalone to local
  • 1.  change controller role from standalone to local
    Posted Oct 28, 2016 12:59 PM
    I am configuring a new controller, I chose 'standalone' as its role during the set-up process.
    Actually what we want to do is put a basic config on it, connect it to our existing mobility domain so that it downloads all the config from the master, and then promote it to master so we can use it (temporarily) as an independent standalone test controller for 6.5.1.
    So how can I change its role to local using the CLI?
    Are there any complications to the process of promoting it back to a master once we have the config on it - we will want it to come back up without joining the existing domain.
  • 2.  RE: change controller role from standalone to local
    Posted Oct 28, 2016 01:20 PM
    What model of controller?
    You should only have to add it as a local controller to the master via
    masterip <ipaddr> ipsec <key>
    Have the controller sync with the Master, then issue
    no masterip
    to have it revert back to Master.
    If this controller is going to be on the same L2 network as the proper master after you are done doing this, you should turn off ADP so it does not terminate any new APs.
    adp discovery disable
  • 3.  RE: change controller role from standalone to local
    Posted Oct 28, 2016 02:36 PM
    Thanks Marcus
    It's a 7220
    I'll give that a go
