Change Country Code - 7240 Controller
This thread has been viewed 22 times
  • 1.  Change Country Code - 7240 Controller
    Posted Aug 19, 2022 10:49 AM
    My organization supports multiple countries with Aruba controllers and APs including the USA, Europe, and the Pacific areas. I have a 7240 controller that I would like to change the country code from Japan to Korea. I am told by my boss that Aruba was able to do this in the past if we mailed the controller back to them they will take care of making that change.
    My question is do I just create an RMA support case to initiate this request? Is there anything else I need to do?
  • 2.  RE: Change Country Code - 7240 Controller
    Posted Aug 22, 2022 04:51 AM
    I'm not aware of a possibility to get a controller RMA-ed to change the country code. Have not seen that before, and can see that it would introduce compliance issues, unless the full controller is replaced by another RW-controller.
    You may try to contact TAC, but expect that it would not be possible, in which case it may be best to contact your Aruba partner or Aruba sales team to see what can be done in this case.
  • 3.  RE: Change Country Code - 7240 Controller
    Posted Aug 23, 2022 01:33 AM
    Herman,
    I was instructed by my manager to open a case for this so that is what I did today. The country code needs to change from "Japan" to "Rest of the World". Regarding your comments, I agree that I am not sure if support will redo the code on the controller itself or if the controller will be swapped/replaced.
    Here are the details of the case I opened:
    Case Reference ID: 5366784462
    Status: Case is generated and in Progress
    Subject: MSM Controller & AP-Change Country Code - 7240 Aruba Wireless Controller
    Product: Aruba 7240 (JP) TAA 4p 10GBase-X (SFP+) 2p Dual Pers (10/100/1000BASE-T or SFP) Controller
    Product Number: JW766A
    Serial number: CX0002100ARB
    Rick
  • 4.  RE: Change Country Code - 7240 Controller
    Posted Aug 23, 2022 05:04 PM
    We usually don't do this, however, we are looking to implement a process to make this change.
    Stay tuned for more details
