change CPPM ip address
  • 1.  change CPPM ip address
    Posted Oct 15, 2013 11:31 AM
    I have already installed ClearPass PM.
    Is it possible to change it's ip address?
  • 2.  RE: change CPPM ip address
    Posted Oct 15, 2013 11:32 AM
    Yes.
    If you go to Administration > Server Manager > Server Configuration, select the server, then you can change the IP address on the System tab.
    You can also change the IP via the CLI by issuing the commands: configure ip <mgmt|data> <ipaddress> netmask <netmask address> gateway <gateway address>
  • 3.  RE: change CPPM ip address
    Posted Oct 15, 2013 11:33 AM
    Just remember if you have a self signed cert that is ip based instead of FQDN you will need to update it.
  • 4.  RE: change CPPM ip address
    Posted Oct 15, 2013 11:38 AM
    ok, that is great.
    Also, I'd like to ask, if there is any way to get CPPM evaluation license quickly?
    I really urgent, and I'd like to get it within an hour!
  • 5.  RE: change CPPM ip address
    Posted Oct 15, 2013 11:40 AM
    Your local Aruba SE or clearpass SE can generate one for you.
