last person joined: 4 hours ago
Change CPPM timezone to UTC?
  • 1.  Change CPPM timezone to UTC?
    Posted Sep 27, 2021 09:53 AM
    I'm having a time finding the correct time zone in CPPM to represent UTC.
    Which choice in that list of hundreds of region/locations is UTC?
    Aaron Klugherz
  • 2.  RE: Change CPPM timezone to UTC?
    Posted Sep 27, 2021 11:48 AM
    There is an entry for UTC as well (at least in the WebUI), or GMT which technically does the same. Not sure if you can select that during the installation in the CLI, but simple to change later.
  • 3.  RE: Change CPPM timezone to UTC?
    Posted Sep 27, 2021 12:53 PM
    Thanks for that, but I've gone through the list (again!) and I can't find anything that says UTC or GMT.
    It would be under Europe/something wouldn't it?
    Aaron Klugherz
  • 4.  RE: Change CPPM timezone to UTC?
    Posted Sep 28, 2021 12:16 AM
    Hi Aaron,
    at least for me (running version 6.10.1) UTC is available:
    Florian Baaske
    Also visit the AirHeads Youtube Channel:
    https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ
    Feel free to visit my personal Blog
    https://www.flomain.de
  • 5.  RE: Change CPPM timezone to UTC?
    Posted Sep 28, 2021 03:50 AM
    Just verified the same on a 6.9.4 ClearPass, it lists GMT/UTC/Universal to select from the list in the WebUI. It's not under Europe, it is between the parts of the world, and an entry of its own, and alphabetical sorted in the list.
    As an alternative, Iceland appears to be on UTC time without DST, so the timezone Atlantic/Reykjavik will have the same result if you want to configure from the CLI.
