Developer
Change Default route if Bad latency/Packet Loss
  • 1.  Change Default route if Bad latency/Packet Loss
    Posted Apr 12, 2020 01:27 AM
    How to change the default route using python if latency>x value Packet loss>Y Value.
  • 2.  RE: Change Default route if Bad latency/Packet Loss
    MVP GURU
    Posted Apr 12, 2020 02:37 AM
    What product ? ArubaCX ? ArubaSW ? Mobility Controller ?
  • 3.  RE: Change Default route if Bad latency/Packet Loss
    Posted Apr 12, 2020 02:44 AM
    Aruba OS switch
  • 4.  RE: Change Default route if Bad latency/Packet Loss
    MVP GURU
    Posted Apr 12, 2020 04:23 AM
    the script python check the bad latency or packet loss ?
    You need to write code for change static route (there is no module for ArubaSW on python with static route for the moment)
  • 5.  RE: Change Default route if Bad latency/Packet Loss
    Posted Apr 12, 2020 06:53 AM
    As alagoutte stated, there's no native solution to do to job you want on AOS-Switch.
    You should set up IP SLA tests, and, with a script, check regularly if it triggers a specified value.
    If so, your script change the route.
    Maybe this could be part of a more global streaming telemetry strategy.
    With CX, you would have been able to do that using 2 solutions :
    - Network Analytics Engine, with a dedicated agent
    - Notifications and websockets.
    The first solution would have been very good because, as it is directly embedded into your switch, you don't need a remote solution.
