Change default VLAN?
  • 1.  Change default VLAN?
    Posted May 14, 2013 10:43 AM
    Building wired network is VLAN2. 3200 install defaults to VLAN1 and will not let me delete it or add VLAN2 with an IP in the same range.
    Am I just missing a step or can this not be done?
    #3200
  • 2.  RE: Change default VLAN?
    Posted May 14, 2013 10:48 AM
    under VLAN 1 do a no ip address and then add VLAN 2 with the ip segment you want to use
    (controller) (config) # interface vlan 1
    (controller) (config) # no ip address
    (controller) (config) #interface vlan 2
    (controller) (config) # ip address (you want to use)
  • 3.  RE: Change default VLAN?
    Posted May 14, 2013 01:24 PM
    You will need to do what vfabian suggested but make sure that first you create a VLAN with a different IP address and set it as controller-ip (conf t , controller-ip cmd in the cli) since you will not be able to delete the IP of VLAN 1 because it is used as the controller IP by default.
  • 4.  RE: Change default VLAN?
    Posted May 14, 2013 01:43 PM
    Thank you both! Exactly what I needed. The steps I was missing:
    different IP since you can't delete vlan1
    controller-ip - totally missed it.
