Change Destination URL in print templates
  • 1.  Change Destination URL in print templates
    Posted Feb 20, 2013 10:15 AM
    Is it possible to change the detination URL in the Sponsor Confirmation print template?
    The default behaviour is to append https://FQDN of clearpass onto the relative href of guest_registration_confirm.php.
    Is it possible to change the URL to be a different DNS name?
    Glyn
  • 2.  RE: Change Destination URL in print templates
    Posted Feb 20, 2013 07:15 PM
    Hi Glyn,
    You can change this under Configuration » Print Templates.  Edit the print template, and in the Notes area change the following:
    {'guest_register_confirm.php'|NwaGetAppUrl}
    to:
    https://whatever.you.want/guest/guest_register_confirm.php
    Note that there are 2 places that this change needs to be made.
  • 3.  RE: Change Destination URL in print templates
    Posted Feb 21, 2013 06:14 AM
    Thanks, I have tried to do that in the base code and from within the template, however the logic appends the base URL thus
    https://NEW DNS/https://CURRENT DNS/guest_register_confirm.php
    Do youknow how to strip the current DNS out of the expression?
    Glyn
  • 4.  RE: Change Destination URL in print templates
    Posted Feb 21, 2013 06:10 PM
    Paste your print template where you have edited it.
    Note that the whole block surrounded by braces needs to be edited, not just the "guest_register_confirm.php" bit.
  • 5.  RE: Change Destination URL in print templates
    Posted Feb 25, 2013 06:18 AM
    Amigodave
    Thanks, I have little experience of Smarty Templates but through a little trial and error I managed to solve the problem.
    Glyn
