Community Feedback
  • 1.  change forum display name
    Posted May 22, 2024 12:26 PM
    How do I change my forum display name?
    I don't want it to be my email address.
  • 2.  RE: change forum display name
    Posted May 22, 2024 02:32 PM
    Use this link: https://auth.arubanetworks.com/change_username
    R-dub
  • 3.  RE: change forum display name
    Posted Jan 07, 2025 09:33 AM
    Do you know after which time the change is active? Will the existing posts renamed, too?
    Thanks!
    Greez,
    Uli
  • 4.  RE: change forum display name
    Posted Jan 08, 2025 08:54 AM
    It takes a while, it is not immediate. Please wait 24 hours.
    Yes, once the name is changed, it will change your post name too.
    Best Regards
    Daniel Ruiz
    If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
    Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 5.  RE: change forum display name
    Posted Jan 08, 2025 08:58 AM
    Thanks a lot, then I will wait ...
    Greez,
    Uli
  • 6.  RE: change forum display name
    Posted Jan 10, 2025 03:08 AM
    Unfortunately, nothing happened even after 48h. I think I need to contact support.
    Greez,
    Uli
  • 7.  RE: change forum display name
    Posted Jan 10, 2025 06:02 AM
    It's a fean, my name change went well. It's the best thing to do, open a ticket to support, see if there is something wrong with the backend.
    BR
    Daniel Ruiz
  • 8.  RE: change forum display name
    Posted Jan 20, 2025 01:14 PM
    Checked the 'weekly consolidated digest' today and guess what: my name has changed!
    Thanks a lot!
    Greez,
    Uli
  • 9.  RE: change forum display name
    Posted Jan 22, 2025 01:46 AM
    I'm glad it took a while, but in the end the name was changed.
    Daniel Ruiz
  • 10.  RE: change forum display name
    Posted Jan 08, 2025 09:53 AM
    Edited by Jamie E Jan 09, 2025 06:12 AM
