Change from PAP when using RADIUS for management
  • 1.  Change from PAP when using RADIUS for management
    Posted Jul 10, 2014 03:40 PM
    Hi!
    I'm setting up my IAP to use an external radius server for authenticating administrators. Although I can't find any way to change from PAP to encrypted protocols. Anyone know if it's possible and in that case where it's configured?
    Best regards,
    Chris
  • 2.  RE: Change from PAP when using RADIUS for management
    Posted Jul 10, 2014 03:59 PM
    Only the pap-based method is supported for management authentication to a radius server on Aruba Instant:  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1320
    The password is encrypted with the Radius Preshared key all the way to the Radius Server.  That is the single biggest determining factor of how secure your information is.
  • 3.  RE: Change from PAP when using RADIUS for management
    Posted Jul 11, 2014 04:48 AM
    Thanx for the quick replies!
  • 4.  RE: Change from PAP when using RADIUS for management
    Posted Jul 10, 2014 08:09 PM
    In the version of InstantOS 4.1 you can use TACACS
  • 5.  RE: Change from PAP when using RADIUS for management
    Posted Jul 10, 2014 08:10 PM
