Change Magic VLAN (Guest network) DHCP Settings
This thread has been viewed 19 times
  • 1.  Change Magic VLAN (Guest network) DHCP Settings
    Posted Mar 23, 2016 04:12 PM
    After a bit of research, I understand that using the UI to create a Guest Network actually creates a VLAN numbered 3333 (called the 'magic VLAN'); addresses on this VLAN are NAT'd through the Virtual Controller's ip address to reach external networks.  Is this correct?
    If so, how do I change the default DHCP pool settings for the magic VLAN?  I have not attempted to change the dhcp pool settings for vlan 3333 in the CLI, as I figured this would break whatever default NAT rules are established when the guest network is created.
    Any help is appreciated!
  • 2.  RE: Change Magic VLAN (Guest network) DHCP Settings
    Posted Mar 23, 2016 04:20 PM
    Under DHCP
  • 3.  RE: Change Magic VLAN (Guest network) DHCP Settings
    Posted Mar 24, 2016 12:13 PM
    Ah, thank you!
