Change Netmask on controller
  • 1.  Change Netmask on controller
    Posted Apr 23, 2018 05:49 AM
    I have a controller Aruba 650 Release 6.4.2.2.
    I need to change the netmask of the controller on interface vlan 1 from 255.255.255.0 to 255.255.252.0.
    When I try to do it, I obtain the following error:
    "Error occurred while executing CLI command :interface vlan 1 ip address 192.168.0.239 255.255.252.0:Error:IP Address Matches the master ip"
    On web user interface, I see that Master IP and loopback interface are the same, so I assigned to the loopback interface an ip address on vlan 150.
    But still I get the same error, when I try to change the netmask of vlan 1.
    Any idea of why I'm getting this error?
    Kind regards.
  • 2.  RE: Change Netmask on controller
    MVP EXPERT
    Posted Apr 23, 2018 07:43 AM
    Is this a standalone controller or in Master-Local deployment? Check this with the below using the CLI
    #show roleinfo
  • 3.  RE: Change Netmask on controller
    Posted Apr 23, 2018 08:04 AM
    It's a standalone controller.
    #show roleinfo
    switchrole:master
  • 4.  RE: Change Netmask on controller
    Posted Apr 23, 2018 09:50 AM
    The loopback is not really necessary.  Try to remove the loopback ip address (it might ask you to reboot) and try again.
  • 5.  RE: Change Netmask on controller
    Posted Apr 24, 2018 05:28 AM
    I moved the loopback interface in another network and it doesn't work.
    I found this string in the running configuration:
    "controller-ip vlan 1"
    Could it be the reason because I can't change the netmask of vlan 1?
  • 6.  RE: Change Netmask on controller
    MVP EXPERT
    Posted Apr 24, 2018 05:33 AM
    Have you rebooted the controller since you changed the controller vlan? The below will tell you if you have any outstanding configuration.
     #show configuration diff
    There's a good chance you have made changes which require a reboot but since the reboot hasn't occurred these changes have not been implemented yet.
  • 7.  RE: Change Netmask on controller
    Posted Apr 24, 2018 05:55 AM
    To be clear, setting a loopback interface allows you to state what ip address and VLAN will be the controller's ip address.  Unfortunately setting a loopback interface consumes a second ip address on a VLAN that already has an ip address.  Setting a loopback is an old way of setting the controller's ip address.   "Controller-ip vlan xxx" should be used instead, because it does not consume an ip address.  Controller-ip vlan xxx conflicts with a loopback and only one should be used.  Changing the controller's ip address or vlan typically requires a reboot, because that is the official ip address that it uses to communicate with access points and external systems.
    Long story short, just use controller-ip vlan xxx and remove the loopback (will probably require a reboot).
