change password with Airwave
  • 1.  change password with Airwave
    Posted Sep 14, 2015 03:45 PM
    We need to change password on over 300 switches. can I do this with Airwave or do I need to log into each switch?
  • 2.  RE: change password with Airwave
    Posted Sep 14, 2015 05:14 PM
    what kind of switches? if managed by Airwave, I believe you can modify this if Aruba switches by templates
  • 3.  RE: change password with Airwave
    Posted Sep 15, 2015 10:58 PM
    where and how to manage the templates? I am new to Air wave, i am not sure how to set the template up.
