Wired Intelligent Edge
Change port configuration - Multiple fallback vlans
  • 1.  Change port configuration - Multiple fallback vlans
    Posted Nov 15, 2018 09:04 AM
    Hello everyone !
    A customer have a particular demand. I'm going to try to explain it :
    He has stacks of switches (from 4 to 9 members).
    Some ports are "PROD" ports and the others are "GUEST" ports.
    All these ports à configured for 802.1X authentication. If the authentication is succesful, then ClearPass push the correct vlan, that's fine.
    However, when the authentication fails, then there is a fallback vlan which depends on the type of port :
    - If the port is a "GUEST", then the fallback vlan is "VLAN GUEST".
    - If the port is a "PROD", then the fallback vlan will depends on the port number in the stack
    -if 1<port number<48 then the fallback vlan is VLAN_100
    -if 49<port number<96 then the fallback vlan is VLAN_200
    -if 97<port number<144 then the fallback vlan is VLAN_300
    -ETC.
    He asked me if there is a fast and easy way to change the type of port, without reconfiguring the port manually.
    For example the port number 38 is a "GUEST" port, and he wants to changes it into a "PROD" port, without reconfiguring the fallback VLANs.
    According to me, some programmation is needed. What would be needed to make that possible ?
    Thanks in advance for your help and for reading ! :)
    PS : I put a schema, to make it the most understandable !
  • 2.  RE: Change port configuration - Multiple fallback vlans
    MVP GURU
    Posted Nov 21, 2018 07:19 AM
    i think, it will be possible with ClearPass (on Enforcement...) but i will no be easy...
    Switch need really to be stacked ?
