Change port to guest portal
  • 1.  Change port to guest portal
    Posted Jul 30, 2014 05:21 AM
    i have realized that a guest can connect to clearpass plicymanager page.
    Can i change this port so i can make a different rule on firewall to block only this port  and the guest can connect only to captive protal.
    Best regards
    Andrea
  • 2.  RE: Change port to guest portal
    Posted Jul 30, 2014 07:38 AM
    Under Server configuration, click on a server and navigate to the network tab. Under application access control, you can restrict certain subnets from accessing different ClearPass applications.
  • 3.  RE: Change port to guest portal
    Posted Jul 30, 2014 09:07 AM
    thanks for your answer.
    this is very helpful for me, but i have two server in cluster and i use the Virtual IP (VIP).
    192.168.123.y (Node a)
    192.168.123.z (Node b)
    192.168.123.x (VIP)
    So if trying to navigate to 192.168.123.x (the VIP) the restriction are still valid?
    Thanks in advance
    best regards
  • 4.  RE: Change port to guest portal
    Posted Jul 30, 2014 09:09 AM
    Yes. Please test and confirm.
  • 5.  RE: Change port to guest portal
    Posted Aug 05, 2014 09:50 AM
    Hi, i will try.
    But, can i use a http port for guest authentication?
    if it yes where i can set it?
    best regards
    Andrea
