We are looking at setting up radius on IAP 305's but we are only able to get the AP's to authenticate via PAP.
We can't find the setting which would allow us on the IAP to change to a different authentication method.
This is the current setup for our radius.
Are you using Captive Portal or 802.1x authentication (WPA2 enterprise) on that SSID? Captive Portal only uses PAP.
It was captive portal, as this was a BYOD network.
So users were meant to logon with there AD Credentials.
So IAP's can only use PAP for captive portal authentication?
In general, Captive Portal over radius only uses PAP.
