Hi, does anyone know how to change a SD-Branch controller hostname in Central? I cannot find where this setting can be modified.
Regards.
Found it already.
What you also can do is when uploading the bulk csv for ip adressen, configure the hostname there.
So you can use this feature the configure all device specific configuration.
