Change soniWALL ARUBA goes offline
  • 1.  Change soniWALL ARUBA goes offline
    Posted Nov 08, 2013 06:12 PM
    I have two sites. The first site has my servers and Aruba controller. The second site is down the road with its own cable modem to a sonicWALL to the switches. I upgraded the sonicWALL with the same ip I get internet and the alarm works but no wireless at the site. Not sure how the site is talking back to the servers and Aruba control over the internet connection. I was just hired and third party is not willing to give me the information about the network. Thank you for any help you can give me.
  • 2.  RE: Change soniWALL ARUBA goes offline
    Posted Nov 08, 2013 06:16 PM
    Do you know the ip address of the Aruba access point?  Can you ping it?  Did it rely on DHCP?  Is DHCP still active at that site?
  • 3.  RE: Change soniWALL ARUBA goes offline
    Posted Nov 08, 2013 06:21 PM
    Yes I know the ip of my controller. If I reinstall the old sonicwall it comes back up. I'm not sure how it talks back to the server room I know the alarm is on a dhcp back to the server and it works with the new sonicwall
  • 4.  RE: Change soniWALL ARUBA goes offline
    Posted Nov 08, 2013 06:25 PM
    I would think one of the servers in the main server room must be a DHCP to setup the connection
  • 5.  RE: Change soniWALL ARUBA goes offline
    Posted Nov 08, 2013 07:17 PM
    Unfortunately, you have to figure all of that out...  Can you take a look at the configuration of the old sonicwall?  We would just be guessing at this point...
