Folks,
We would like to use the Central API to reset our guest network SSID passphrase programatically, but the API does not seem to provide this functionality? Am I wrong? Is there another way to programatically change a SSID passphrase?
Thanks for any tips!
I know this is a quite old thread but I face the same issue and I can't find a way to solve it without using Templates.
Did you found a solution or can someone help us?
Thank you,
As far as I can see, changing the configuration of a Device in Central is possible if you use template groups. Just set the passphrase as a variable in the template and change the variable for your IAP's.
It is not supported for GUI Groups.
Did you check pycentral on github?
Best, Gorazd
