Change Subnet
  • 1.  Change Subnet
    Posted Feb 15, 2013 10:47 AM
    We recently increased the IP range we issue and went from a 255.255.252.0 mask to a 255.255.240.0 mask. When I go into my Aruba controller to change this I get an error. We have an Aruba 2400. When I ssh to the device and do a sh run The only place I see an IP and mask assigned is on int vlan 1. I got into that interface and try to change the netmask and I get an error that the IP address is the same as the master and cannot be updated even though I am giving it the same IP address it had before. The only change I am making is to the subnet. Any suggestions on how I might be able to change this? I tried through the web panel as well and got the same error.
    Michael
  • 2.  RE: Change Subnet
    Posted Feb 15, 2013 10:51 AM
    You might have to do a no ip address first and shutdown the interface.
  • 3.  RE: Change Subnet
    Posted Feb 15, 2013 12:10 PM
    Hello
    I think it will fit you better having Vlan pool instead of doing that...
    Vlan pooling will let you associalte many vlans to a single SSID.
    Try not having more than 10 vlans associated to one SSID.
    It is recommended that you have small blocks of 254 host...  If not you will have big broadcast domains... which lead to ping drop and retrasnmitions...
    you still can do /23 but in this case try if you can drop broadcast and musticast on the SSIDs.
    Cheesr
    Carlos
